FREQ2
Bulk Data Entry Defines a set of frequencies to be used in the solution of frequency response problems by specification of a starting frequency, final frequency, and the number of logarithmic increments desired.
| FREQ2 | SID | F1 | F2 | NF |
| FREQ2 | 6 | 1.0 | 8.0 | 6 |
| SID | Set identification
number. No default (Integer > 0) |
| F1 | First frequency in
set. No default (Real > 0.0) |
| F2 | Last frequency in
set. No default (Real > 0.0, F2 > F1) |
| NF | Number of logarithmic
intervals. Default = 1 (Integer > 0) |
- FREQ2 entries must be selected with the I/O Options or Subcase Information command FREQUENCY = SID.
- The units for F1 and F2 are cycles per unit time.
- The frequencies defined by this entry are
given by fi =
F1*e(i-1)d
where, and i = 1, 2, ..., (NF + 1).
- All FREQi entries with
the same set identification numbers will be used. Duplicate frequencies will be
ignored.
and
are considered duplicated if:Where,
- DFREQ
- User parameter with a default of 10-5 *
- The maximum and minimum excitation frequencies of the combined FREQi entries
- This card is represented as a load collector in HyperMesh.
