The .gpf file is an OptiStruct
ASCII format results file.
File Creation
Creation of this file is controlled by the GPFORCE I/O
Option.
File Contents
| Result |
Description |
| Grid point force balance
table |
table for linear static analysis. |
File Format
The file is divided up by iteration. Output from each iteration starts with a line in
the following format:
ITERATION |
Iteration_number |
- Data
- Description
- ITERATION
- Keyword denoting the beginning of a new iteration.
- Iteration_number
- Iteration number.
Each iteration section contains a force balance table for each node, for which this
output format was selected, in each linear static subcase.
These tables are given the following header:
Grid point
forces for node |
Node_id |
Subcase
ID = |
Subcase_id |
- Data
- Description
- Node_id
- ID of the node to which the force balance table applies.
- Subcase_id
- User-defined subcase ID to which the force balance table applies.
The force information is provided, for each contributing element, constraint or load,
in the following format:
Force_type |
Element_id |
x-force |
y-force |
z-force |
x-moment |
y-moment |
z-moment |
- Data
- Description
- Force_type
- SPC - Force contribution of single-point
constraints.
- Appl. - Force contribution of Applied loads.
- F-MPC - Force contribution of rigid elements and
multi-point constraints. 2
- Elem - Force contribution of elastic elements.
- Rigid - Force contribution of rigid elements
(RBEx, RROD,
RSPLIN, and so on). 2
- MPC - Force contribution of MPCs.
- JOINTG - Force contribution of JOINTG elements.
- Total - The sum of all the force contributions.
- Element_id
- Only valid for force contributions from elastic elements or Rigid
elements. This is the element's ID.
- x-force
- The x-translational component of the force.
- y-force
- The y-translational component of the force.
- z-force
- The z-translational component of the force.
- x-moment
- The x-rotational component of the force.
- y-moment
- The y-rotational component of the force.
- z-moment
- The z-rotational component of the force.
- The I/O Option Previously Supported Results controls
the frequency of output for analytical results during an optimization.
- By default, the F-MPC output contains GPF
contribution from both MPCs and rigid body elements (RBEx,
RROD, RSPLIN, and so on).
Additionally, rigid body element contributions and MPC contributions are
separately printed to the .gpf file. The SYSSETTING(GPFMPC=FMPC/SEPAR)
options can be used to control this output.
