HYBDAMP
I/O Options and Subcase Information Entry The HYBDAMP command can be used in the I/O Options section to request modal damping as a function of the natural frequency of the model in Dynamic Analysis.
HYBDAMP = option
| Argument | Options | Description |
| option | <SID> No default |
- HYBDAMP can be set at the global level in the I/O Options section. It can exist only once in the I/O Options section.
