INIPS
Bulk Data Entry Defines initial plastic strain values and settings for elements in nonlinear analysis.
| INIPS | ID | ETYPE | CIDA |
| SECT | NSEC | SEC1 | SEC2 | SEC3 | etc. |
| EORS | EID/ESETID | CIDB | etc. | ||||||
| VALUE | PS1 | PS2 | PS3 | etc. | |||||
| HARD | EQVPLS | BKS1 | BKS2 | BKS3 | etc. |
When ETYPE = SHELL and the SECT line is given, each VALUE line defines initial plastic strain for a shell section; and so, for any shell element (with EID) or shell element set (with ESETID), the number of VALUE lines must be NSEC.
Alternate Format (Initial Plastic Strain from H3D File)
| INIPS | ID | ASSIGN | SUBID | RSTYPE | |||||
| EORS | EID1/ESETID1 | EID2/ESETID2 | EID3/ESETID3 | EID4/ESETID4 | EID5/ESETID5 | EID6/ESETID6 | EID7/ESETID7 | ||
| EID8/ESETID8 |
Example 1
| INIPS | 7 | ||||||||
| ELEM | 1001 | ||||||||
| VALUE | 3.33e-2 | -1.67e-2 | -1.67e-2 | 0.0 | 0.0 | 0.0 | |||
| HARD | 5.0e-2 | ||||||||
| ESET | 200 | ||||||||
| HARD | 50.0 | 50.0 | 0.0 |
Example 2
| INIPS | 8 | SHELL | -1 | ||||||
| SECT | 2 | ||||||||
| ELEM | 101 | ||||||||
| VALUE | 3.33e-2 | 0.0 | 0.0 | ||||||
| VALUE | -3.33e-2 | 0.0 | 0.0 | ||||||
| ELEM | 102 | ||||||||
| HARD | 3.33e-2 | 20.0 | 5.0 | 0.0 | |||||
| HARD | 3.33e-2 | -20.0 | -5.0 | 0.0 |
Example 3 (Alternate Format - Plastic Strain from H3D File)
| INIPS | 7 | 19 | 3 | ||||||
| ELEM | 1001 | 2002 | 3003 |
Example 4 (Alternate Format - Plastic Strain from H3D File)
| INIPS | 8 | 29 | 6 | ||||||
| ESET | 2 | 5 | 9 | ||||||
| ESET | 9 | 19 | 29 |
| ID | Each
INIPS Bulk Data Entry must have a unique
ID. No default (Integer > 0) |
| ETYPE | Type of elements for
which initial plastic strain is applied.
| CIDA | Coordinate system
identification number or flag for the plastic strain components.
| SECT | Keyword indicating the start of continuation line(s) for the shell sections. | |
| NSEC | Number of shell
sections where initial plastic strain is applied for shell
elements. No default (1 ≤ Integer ≤ 6) |
| SEC(i) | Through-thickness
position for the shell sections. SEC(i) must
be either all blank or all non-blank, that is, the number of
SEC(i) must be either
NSEC or zero; and
SEC(i) must be given in ascending order
if all non-blank. If left blank, this implies the sections are located uniformly through the shell thickness, starting at the bottom surface and ending at the top surface. A Real value is the multiplier to shell thickness to find the location. -0.5 is the bottom surface of the shell element and 0.5 is the top surface. The through-thickness positive direction, pointing from the bottom surface to the top surface, is determined by the right-hand rule and the order in which the grid points are listed on the connection entry. It is the same as the convention for Z1/Z2 of PSHELL. Default = Blank (Blank or -0.5 ≤ Real ≤ 0.5) |
| EORS | Flag indicating an
element, or an element SET is selected in the following field.
| EID/ESETID | Identification number
of the element or the element SET to which the plastic strain
values apply. No default (Integer > 0) |
| CIDB | Coordinate system
| VALUE | Keyword indicating the start of a continuation line for the plastic strain components. | |
| PS(i) | Plastic strain
components. 4 No default (Real) |
| HARD | Continuation line to define plastic hardening information. | |
| EQVPLS | Value of the
equivalent plastic strain. Default = Blank (Real) |
| BKSi | Values of the back
stresses. Default = Blank (Real) |
| Alternate Format Description (plastic strain from H3D file) | ||
| ASSIGN | Identification number
of ASSIGN, H3DRES. When
ASSIGN is specified,
SUBID should also be specified and the
VALUE continuation line is not
allowed. This field is mandatory for Alternate Format (plastic strain from H3D file). No default (Integer > 0) |
| SUBID | Subcase identification
number where initial plastic strain is applied from the H3D
file. This field is mandatory for Alternate Format (plastic strain from H3D file). No default (Integer > 0) |
| EID#/ESETID# | Identification number
| RSTYPE | Results type to read
in from the specified H3D file.
- INIPS and IPSADD should not have the same ID.
- The INIPS Bulk Data Entry is selected by the Subcase Information Entry INIPS.
- Initial plastic strain is only
supported for nonlinear static analysis (both small and large displacement
analysis). Initial plastic strain is supported for solid elements
(CHEXA, CPENTA,
CPYRA and CTETRA) and shell
elements (CQUAD4, CTRIA3,
CQUAD8 and CTRIA6),
only.Initial plastic strain is currently not supported for:
- Solid elements with user-defined material in LGDISP analysis.
- Elements with MATMDS material.
- For initial plastic strain of solid
elements, the following 6 plastic strain components are needed for each
VALUE:
Where x, y, and z are the axes of the coordinate system selected via CIDA and CIDB.
For initial plastic strain in element or material coordinate system of shell elements, the following 3 plastic strain components are needed for each VALUE line:For initial plastic strain in the basic or a prescribed coordinate system of shell elements, the following 6 plastic strain components are needed for each VALUE line: - Alternate Format (Plastic strain
from H3D file):
- VALUE continuation line is not allowed for the Alternate Format when plastic strain is sourced from the H3D file.
- For shell elements, currently only the equivalent of NSEC=2 is supported (Z1 and Z2 layers) to apply the plastic strain, as the number of layers where plastic strain data is available can be identified from the H3D file.
- Currently, only H3D files output from OptiStruct and HyperForm are supported.
