IPSADD
Bulk Data Entry Defines initial plastic strain condition for nonlinear static analysis as a union of INIPS entries.
| IPSADD | ID | IS1 | IS2 | IS3 | IS4 | IS5 | IS6 | IS7 | |
| IS8 | IS9 | etc. |
| IPSADD | 9 | 101 | 102 | 103 |
| ID | Each
IPSADD Bulk Data Entry must have a unique
ID. No default (Integer > 0) |
| IS(i) | Identification number
of INIPS entries. The
IS(i) values must be unique. No default (Integer > 0) |
- IPSADD and INIPS should not have the same ID.
- The IPSADD Bulk Data Entry is selected by the Subcase Information Entry INIPS.
