JOINTM
Bulk Data Entry Defines a joint using two grids which have a marker card associated with them. Joints are only valid in a multibody solution sequence.
| JOINTM | JID | JTYPE | M1 | M2 |
Example 1
| JOINTM | 3 | BALL | 345 | 231 |
Example 2
| JOINTM | 4 | UNIV | 456 | 899 |
| JID | Unique joint
identification number. (Integer > 0) |
| JTYPE | Joint type. 1
| M1, M2 | Marker identification
numbers. M1 and M2 must
belong to different bodies and must have a marker card
associated with them. (Integer > 0) |
- Definition of the different joint
types:
JTYPE Definition Joint Orientation BALL M1, M2 M1, M2 must coincide. FIX M1, M2 M1, M2 must coincide. REV M1, M2 M1, M2 must coincide. The joint axis will be along the Z-axis of marker M1.
TRANS M1, M2 M1, M2 must be along the joint axis. The joint axis will be along the Z-axis of marker M1.
CYL M1, M2 M1, M2 must be along the joint axis. UNIV M1, M2 M1, M2 must coincide. CV M1, M2 M1, M2 must coincide. PLANAR M1, M2 M1, M2 must be in the joint plane. INLINE M1, M2 PERP M1, M2 PARA M1, M2 INPLANE M1, M2 ORIENT M1, M2 No relative rotation.
