MASSSET
Subcase Information Entry The MASSSET command can be used to select a linear mass combination.
MASSSET = option
MASSSET = 3
| Argument | Options | Description |
| option | <ID> No default |
- If there is no MASSSET defined in the subcase, the base mass is used by default.
- This case control command can be used in linear static analysis and aeroelastic trim analysis.
- The additional mass can be defined in the BEGIN,MASSID entry. Concentrated mass elements or general structural elements could be used to apply the mass to the structure. The stiffness of the structural elements is ignored in the MASSID section.
- The entries in the
BEGIN,MASSID section could have the
same ID as entries in the global section. The property or material
information from global part is used if it is not defined in the
BEGIN,MASSID section.
BEGIN MASSID=11 LABEL='mass increment using conm2s' CONM2 100 15 0 1.0 BEGIN MASSID=12 LABEL='mass increment using CBEAM' CBEAM 81 2 1 61.0 0.0 0.0 PBEAML 2 2 ROD + + 5.0 MAT1 2210000.0 0.3 7.9-9
