MBCNTR
Bulk Data Entry Defines a Multibody contact between rigid bodies.
| MBCNTR | CID | SID1 | SID2 | CNFTYPE | PENAL | COR | MUSTAT | MUDYN | |
| CFFTYPE | STVEL | FTVEL |
| MBCNTR | 2 | 4 | 7 | POISSON | 1E6 | .5 | .7 | .3 | |
| COUL | .1 | .8 |
| CID | Contact identification number. No default (Integer > 0) |
| SID1 | Set identification number for a set of
elements. No default (Integer > 0) |
| SID2 | Set identification number for a set of
elements. No default (Integer > 0) (SID2 ≠ SID1) |
| CNFTYPE | Contact normal force type. Default = POISSON |
| PENAL | Penalty factor. Default = 1.0 (Real > 0.0) |
| COR | Coefficient of restitution. Default = 1.0 (0.0 ≤ Real ≤ 1.0) |
| MUSTAT | Coefficient of static
friction. Default = 0.0 (Real ≥ 0.0) |
| MUDYN | Coefficient of dynamic
| CFFTYPE | Contact friction force type.
| STVEL | Stiction transition velocity. Defines
the slip velocity at which the static coefficient of friction
MUSTAT is applied. Default = 0.0 (Real ≥ 0.0) |
| FTVEL | Friction transition velocity. Defines
the slip velocity at which the dynamic coefficient of friction
MUDYN is applied. Default = 0.0 (Real ≥ 0.0) |
- This card is represented as a group in HyperMesh
