MBMNTC
Bulk Data Entry Defines a curve moment at a grid point by specifying a vector.
| MBMNTC | SID | G1 | CID | CVID | G3/N | N | N | G2 | |
| INT | EID |
| MBMNTC | 3 | 345 | 4 | 0.0 | 1.0 | 0.0 | |||
| AKIMA | 42 |
| SID | Load set identification number. No default (Integer > 0) |
| G1 | Grid point identification number where
the action force is applied. No default (Integer > 0) |
| CID | Coordinate system identification number.
Blank or 0 infer the basic coordinate system. Default = 0 (Integer ≥ 0, or blank) |
| CVID | Set identification number of the
MBCRV entry that gives the load versus independent variable
measured in the coordinate system defined by CID. (Integer > 0) |
| G3 | Grid point identification number to
optionally supply N1, N2,
N3 in conjunction with G1. (Integer > 0) |
| N,N,N | Defines the direction of the force
vector. At least one of the vector components must be non-zero. Default = 0.0 (Real) |
| G2 | Grid point identification number where
the reaction force is applied. If blank or zero, then the force is an action-only
force. Default = 0 (Integer ≥ 0) |
| INT | Interpolation type.
(Character) |
| EID | Set identification number of the MBVAR for the independent variable
expression. Default = TIME (Integer ≥ 0 or blank) |
- This card is represented as a moment load in HyperMesh.
