MBPCRV
Bulk Data Entry Defines a Multibody Parametric Curve using node sets.
| MBPCRV | PCID | UCLOSED | CRVPTS | ||||||
| G1 | G2 | G3 | G4 | G5 |
| MBPCRV | 1 | 1 | 0 | 1 | 5 | ||||
| 201 | 202 | 203 | 204 | 205 |
| PCID | Parametric curve identification
number. No default (Integer > 0) |
| UCLOSED | Specify.
| CRVPTS | Curve points.
(BOOLEAN: 0, 1) |
| G1,G2, ... | Ordered list of grids defining the curve. |
- This card is represented as a set in HyperMesh.
