MBPTCV
Bulk Data Entry Defines a Point to Parametric Curve Constraint.
| MBPTCV | JID | GID | PCID | G3 | V0 |
| MBPTCV | 1 | 21 | 2 | 25 | 0 |
| JID | Joint identification
number. No default (Integer > 0) |
| GID | Grid identification number
corresponding to the point which is sliding on a curve. No default (Integer > 0) |
| PCID | Parametric curve
(MBPCRV) identification number. No default (Integer > 0) |
| G3 | This grid specifies the
guess for the initial contact point on the curve. Default is GID (Integer > 0) |
| V0 | Specifies the initial
sliding velocity of the contact point, as measured by an observer on
the curve, placed at the contact point. Default = 0.0 (Real) |
