MBSEQ
Bulk Data Entry Defines the simulation sequence for the multibody solver.
| MBSEQ | ID | SID1 | SID2 | SID3 | etc | etc |
| MBSEQ | 9 | 99 | 12 | 43 |
| ID | Unique identification
number. (Integer > 0) |
| SID1, SID2, etc. | IDs of the simulation sequence. Valid
IDs are:
(Integer > 0) |
- Every time an MBSIM card is encountered, a simulation is performed on the multibody model. The initial condition for the next MBSIM will be the ending condition of the current simulation.
- This card is represented as a load collector in HyperMesh.
