MBSFRCE
Bulk Data Entry Defines an expression scalar load on two grid points.
| MBSFRCE | SID | G1 | G2 | EID |
| MBSFRCE | 3 | 345 | 346 | 1 |
| SID | Load set
| G1 | Grid point
| G2 | Grid point
identification number. No default (Integer > 0 |
| EID | Expression
identification number of the MBVAR entry. No default (Integer > 0) |
- MBSFRCE applies a translational action-reaction force along the line of action defined by the line segment connecting G1 and G2.
- The action force is applied to G1 and the reaction force is applied to G2.
- Tensile force is positive.
