MBSMNTC
Bulk Data Entry Defines a curve scalar moment on two grid points along the specified vector.
| MBSMNTC | SID | G1 | G2 | CVID | G3/Vx | Vy | Vz | ||
| INT | EID |
| MBSMNTC | 3 | 345 | 346 | 2 | 0 | 1.0 | 1.0 | ||
| AKIMA | 1 |
| SID | Load set
| G1 | Grid point
| G2 | Grid point
| CVID | Set identification
number of the MBCRV entry that provides the
load versus independent variable measured in the coordinate
system defined by CID. (Integer > 0) |
| G3 | Grid point
identification number to optionally supply
Vx, Vy, and
Vz in conjunction with
G1. (Integer >: 0) |
| Vx | X component of vector V | |
| Vy | Y component of vector V | |
| Vz | Z component of vector V | |
| INT | Interpolation type.
| EID | Set identification
number of the MBVAR for
the independent variable expression. Default = TIME (Integer ≥ 0 or blank) |
- MBSCMTC applies a scalar action-reaction moment on G1 and G2 along the vector defined by Vx, Vy, and Vz.
- The action moment is applied to G1 and the reaction moment is applied to G2.
- Right hand rule defines the positive moment.
