MODEL
I/O Options and Subcase Information Entry The MODEL command can be used in the I/O Options section to request output of only a subset of the model and related results for H3D and OUTPUT results files as well as for CMS superelements.
MODEL = elset, gridset, rigidset
| Argument | Options | Description |
| elset | <SID, PLOTEL, ALL,
NONE> Default (analysis run) = ALL Default (CMS SE creation) = NONE |
| gridset | <SID, ALL,
NONE> Default (AVL/EXCITE generation run) = ALL |
| rigidset | <RIGID/ALL,
NORIGID/NONE, SID> Default (analysis run) =RIGID/ALL Default (CMS SE creation) = NORIGID/NONE |
- For CMS superelements output in *.h3d format, only the ASET, BSET, or CSET degrees of freedom are output when the MODEL data is not present. When the MODEL data is present, the .h3d file contains the ASET, BSET, or CSET degrees of freedom and what is specified on the MODEL data.
- In addition to the results output, the MODEL data controls the portion of the model that is written to the .op2 and .h3d files.
- The gridset always contains the ASET, BSET, or CSET grids along with any grids specified on the model data. In addition, all grids associated with the elements in the elset are included in the gridset. The same is true for grids associated with the rigid elements if RIGID is specified.
