MONCARL
Bulk Data Entry Monte-Carlo Simulation control settings for the non-parametric method for variation modeling.
| MONCARL | SID | VARTYP | |||||||
| STRVAR | MSVAR | KSVAR | BSVAR | K4SVAR | |||||
| FLUVAR | MFVAR | KFVAR | BFVAR | AFSVAR | K4FVAR | ||||
| DMIG | SID1 |
| MONCARL | 2 | ALPHAVAR | |||||||
| STRVAR | 0.02 | 0.01 | 0.004 |
| SID | Identification number. No default (Integer > 0) |
| VARTYP | Variability type.
| STRVAR | Structural Variability parameters flag are to follow. | |
| MSVAR | Structural Mass Variability
value. Default = 0.0 (Real ≥ 0.0) |
| KSVAR | Structural Stiffness Variability
| BSVAR | Structural Viscous Damping
Variability value. Default = 0.0 (Real ≥ 0.0) |
| K4SVAR | Structural Material Damping
| FLUVAR | Fluid Variability parameters flag are to follow. | |
| MFVAR | Fluid Mass Variability
| KFVAR | Fluid Stiffness Variability
| BFVAR | Fluid Viscous Damping Variability
| AFSVAR | Fluid Structure Interaction Matrix
| K4FVAR | Fluid Material Damping Variability
| DMIG | (Optional) Flag indicating that the above variability values are applied to the specified DMIGs below. | |
| SID1 | Identification number of a SET Bulk Data Entry of TYPE=LABEL (this SET lists the various DMIG matrices for which the above variability values are applicable). 2 |
- MONCARL is only supported for Modal Frequency Response Analysis. Also, only 1 Modal Frequency response subcase can be defined for MONCARL.
- The optional
DMIG continuation line can be used to specify
variability parameters for DMIG matrices which are
defined as a LABEL-based SET Bulk Data Entry, such as:
SET,<SID1>,LABEL +,<DMIG1>,…,<DMIG2>The labels DMIGi can reference are:- DMIG matrices referenced by K2GG, M2GG, B2GG, K42GG entries.
- H3D Superelement referenced by ASSIGN entries.
- IDs of root internal superelements.
- Multiple MONCARL entries with the same ID can be used to specify different variabilities to individual superelement matrices, and the DMIG continuation line can be omitted from at the most one MONCARL entry. If the DMIG line is omitted, then the specified variabilities will be applied to the residual structure (that is, each of the structural matrices excluding the DMIG matrices with separately defined variabilities).
