MONCARL
I/O Options and Subcase Information Entry Used in the Subcase Information section to identify the Monte-Carlo simulation control settings for non-parametric method for variation modeling.
MONCARL(NSAMPLE=N,SEED=S,OFFD=OD,NGRP=NG,ZERO=EPS) = option
Definition
| Argument | Option | Description |
| N | <n> Integer > 0 (Default = 0) |
| S | <s> Integer > 0 (Default = 777) |
| OD | <od> Real (Default = 1.0) |
| NG | <ng> Integer > 0 (No default) |
| EPS | <eps> Real > 0.0 (No default) |
| option | < SID > No default |
- MONCARL Bulk Data Entries will not be used unless selected in the Subcase Information section.
- MONCARL is only supported for Modal Frequency Response analysis and only a single subcase of Modal Frequency Response subcase can be defined.
- Multi-level DDM is not supported along with MONCARL, regardless of whether or not the NGRP option is used on MONCARL.
