MONPNT3
Bulk Data Entry Sums select Grid Point Forces to a user chosen monitor point.
| MONPNT3 | NAME | LABEL | |||||||
| AXES | GRIDSET | ELEMSET | CP | X | Y | Z | XFLAG | ||
| CD | |||||||||
| MONPNT3 | WING20 | Wing Load | |||||||
| 23 | 2 | 3 | 20.0 | 15.0 | 25.0 | A | |||
| NAME | Character string of up to 8 characters identifying the
monitor point. No default (Character) |
| LABEL | A character string that identifies and labels the monitor
point. Default = blank (Character, a maximum of 56 characters, fields 3 through 9) |
| AXES | Component axes about which to sum. No default (Integer > 0, up to six unique digits (0 < digit ≤ 6) may be placed in the field with no embedded blanks) |
| GRIDSET | Identification number of a SET1 Bulk Data
Entry which has a list of grids to be included in the monitored
point. No default (Integer) |
| ELEMSET | Identification number of a SET1 Bulk Data
Entry which has a list of elements to be included in the
monitored point. Default = blank (Integer) |
| CP | The identification number of a coordinate system in which the
input (x,y,z) coordinates are defined. Default = 0 (Integer ≥ 0) |
| X, Y, Z | The coordinates in the CP coordinate
system about which the forces are to be summed. Default = 0.0 (Real) |
| XFLAG | Exclusion flag. Exclude the indicated grid point force types
from the summation at the monitor point.
Default = Blank (no type excluded) |
| CD | The identification number of a coordinate system in which the
results are output. Default = The coordinate system specified by the CP field (Integer ≥ 0) |
- The MONPNT3 entry is available for static aeroelastic analysis.
- If ELEMSET is blank, no contributions are made from the set of elements attached to the grid.
- Fictitious grids or elements do not produce error or warning messages.
