MOTNJ
Bulk Data Entry Defines a constant joint motion.
| MOTNJ | SID | JID | MTYPE | D | DTYPE | D0 | V0 |
| MOTNJ | 3 | 345 | TRANS | 1.0 | DIS |
| SID | Load set
identification number. (Integer > 0) |
| JID | Joint identification
| MTYPE | TRANS or ROT, ignored for revolute and translational joints. | |
| D | Value of
motion. (Real) |
| DTYPE | Motion data type.
| D0 | Initial displacement if motion data is of type velocity or acceleration, ignored otherwise. | |
| V0 | Initial velocity, if motion data type is acceleration, ignored otherwise. |
- Joint motion can only be applied to cylindrical joints (MTYPE = TRANS or ROT), revolute joints (MTYPE = ROT), and translational joints (MTYPE = TRANS).
- The MOTNJ Bulk Data Entry should be selected in the MOTION Subcase Information section, if it is to be included in the analysis.
