NLENRG
Bulk Data Entry Defines parameters for energy variables printout for implicit nonlinear static, implicit nonlinear transient analyses, explicit dynamic analysis, and linear static analysis (with Neuber correction).
| NLENRG | ID | PARAMi | VALUEi |
| “ESET” | SET1 | SET2 | etc. |
| “CONTACT” | CID1 | CID2 | etc. |
| “PGAP” | PGID1 | PGID2 | etc. |
| NLENRG | 99 | FREQ | 2 | ||||||
| ESET | 1001 | 1002 | |||||||
| CONTACT | ALL | ||||||||
| PGAP | 100 | 200 |
| ID | Each NLENRG Bulk Data Entry must have a
unique ID. No default (Integer > 0) |
| PARAMi | Name of parameter. | |
| VALUEi | Value of parameter. | |
| ESET | Keyword indicating energy variables are to be printed for selected element SETs. | |
| SETi | Element SET identification number. No default (Integer > 0) |
| CONTACT | Keyword indicating energy variables are to be printed for selected contact interfaces. | |
| CIDi |
No default |
| PGAP | Keyword indicating energy variables are to be printed for selected CGAP/CGAPG elements. | |
| PGIDi |
No default |
| PARAMi | VALUEi | SI Unit Example |
| FREQ | Output frequency in increments. This is applicable to both
Implicit and Explicit nonlinear subcases. Default = 1 (for Implicit analysis) Default = 100 (for Explicit analysis) (Integer > 0) |
| HG | Control for output of HyperGraph
data files (*.nlm) for Implicit nonlinear
subcases. 3
4
- The NLENRG Bulk Data Entry is selected by the NLENRG Subcase Information command. In the following comments, filename implies the actual name of the input file or model.
- When NLENRG Bulk/Subcase Entry pair are defined, the energy variables are printed into the filename_e.out file for all implicit nonlinear subcases.
- For implicit nonlinear subcases,
HyperGraph data file for the global energy
variables is named as filename_s<n>_e.nlm for each
nonlinear subcase; where, <n> denotes the subcase
ID. HyperGraph data file for the per-entity energy variables, if activated is named as for each entity in each nonlinear subcase:
- filename_eset<ID>_s<n>_e.nlm (Element SET-based energy)
- filename_cont<ID>_s<n>_e.nlm (Contact Interface-based energy)
- filename_pgap<ID>_s<n>_e.nlm (PGAP Property-based energy)
Where,- <ID>
- Denotes the entity ID
- <n>
- Denotes the subcase ID
The files *.nlm can be read and plotted by HyperGraph and a HyperGraph session file named filename_energy.mvw is created for straightforward plotting of the global energy variables.
For Explicit nonlinear subcases, the global energy variables are output to a file named filename_s<n>_e.expl for each explicit subcase, where <n> denotes the subcase ID and a HyperGraph session file named filename_expl_energy.mvw is created for straightforward plotting of the global energy variables.
- For implicit nonlinear subcase, if NLENRG entry is not defined, the global energy variables are written into a HyperGraph data file (filename_s<n>_e.nlm) for each time increment. However, the output of the filename_e.out file requires the presence of NLENRG Bulk/Subcase Entry pair.
- The energy output for both
Implicit and Explicit Subcases are listed in the table below.
Energy Variables Contents of the Energy Variables Implicit Nonlinear Subcases Explicit Nonlinear Subcases Linear Static Subcases (with Neuber correction) Internal Energy Total strain energy which includes elastic strain energy, plastic dissipation energy, viscoelastic dissipation energy and damage dissipation energy. Supported Supported Supported Plastic Dissipation Energy Energy dissipated by plastic deformation. Supported Supported Supported Hourglass Energy Energy dissipated by artificial hourglass control. NA Supported NA Contact Normal Energy Contact constraint energy in normal direction due to penalty constraint enforcement. Unsupported Supported Unsupported Contact Frictional Energy Energy dissipated by contact friction. Unsupported Supported NA Static Stabilization Energy Energy dissipated by artificial static stabilization. Supported NA NA Contact Stabilization Energy Energy dissipated by artificial static contact stabilization. Supported NA Unsupported Kinetic Energy Kinetic energy Unsupported Supported NA Total Energy The sum of Internal energy, Hourglass energy, Contact Normal energy, Contact Frictional energy, Static Stabilization energy, Contact Stabilization energy and Kinetic energy. Unsupported Supported NA External Work External work Unsupported Supported NA - Implicit nonlinear analysis does not support hourglass elements and so hourglass energy is always zero for implicit subcases.
- Energy output for implicit nonlinear analysis is only controlled by the NLENRG Bulk/Subcase Entry pair. There is no influence of NLMON or NLOUT entries on the nonlinear energy output. Additionally, energy is always output on-the-fly dynamically during the analysis.
- For Explicit Dynamic Analysis, currently only the FREQ option is supported.
- The following table summarizes the
energy output files:
Subcase Types Input Options Energy Output Files Energy Output Implicit Nonlinear Subcases Default (no NLENRG Bulk/Subcase pair) filename_s<n>_e.nlm and filename_energy.mvw See Comment 4 With NLENRG Bulk/Subcase pair filename_s<n>_e.nlm, filename_eset<ID>_s<n>_e.nlm, filename_cont<ID>_s<n>_e.nlm, filename_pgap<ID>_s<n>_e.nlm, filename_e.out and filename_energy.mvw See Comment 2, 3 and 4 Explicit Nonlinear Subcases Default (no NLENRG Bulk/Subcase pair) filename_s<n>_e.expl and filename_expl_energy.mvw See Comment 2 and 8 With NLENRG Bulk/Subcase pair filename_s<n>_e.expl and filename_expl_energy.mvw NLENRG for Explicit is only to allow usage of FREQ option. See Comment 2 and 8 Linear Static Analysis Subcases Default (no NLENRG Bulk Data/Subcase Information Entry pair) None None With NLENRG(NEUBER) in Subcase Information and NLENRG Bulk Data Entry. filename_e.out See Comment 4. FREQ is not supported for Linear Static Energy output.
