OTIME
I/O Options and Subcase Information Entry Used in the I/O Options or Subcase Information sections to request a set of times for output requests for Transient Analysis for all subcases or individual subcases, respectively.
OTIME = option
| Argument | Options | Description |
| option | <ALL, SID> Default = ALL |
- When an OTIME command is not present, the output for all times will be computed.
- This command is particularly useful for requesting a subset of the output (for example, stresses at only peak times, and so on).
