PACABS
Bulk Data Entry Defines the properties of an acoustic absorber element.
| PACABS | PID | SYNTH | TID1 | TID2 | TID3 | CUTFR | B | ||
| K | M |
| PACABS | 3 | 2 | 3 | 5 | 400.0 |
| PID | Property identification
number. No default (Integer > 0) |
| SYNTH | Controls the calculation
of the B, K, and
M values.
(Character) |
| TID1 | Identification number of a
TABLEDi entry that defines the resistance.
2 Default = blank (Integer > 0) |
| TID2 | Identification number of a
TABLEDi entry that defines the reactance.
| TID3 | Identification number of a
TABLEDi entry that defines the weighting
function. 2 Default = blank (Integer > 0) |
| CUTFR | Cutoff frequency for
tables referenced above. (Real > 0.0) |
| B | Equivalent Damping per
unit area. Default = blank (Real ≥ 0.0) |
| K | Equivalent Stiffness per
| M | Equivalent Mass per unit
- The PACABS Bulk Data Entry should only be referenced by a CHACAB Bulk Data Entry.
- TID1 and TID2 should be specified (TID3 is not mandatory), if SYNTH field is set to YES. The equivalent structural model will be derived from TIDi. If TID3 is blank, then the weighting function is set to 1.0.
- The TIDi tabular data should be defined as a function of frequency in cycles/unit time.
- If SYNTH=NO, then B, K, or M fields will be used to derive the Equivalent Structural Model.
