PANEL
Bulk Data Entry Defines up to four sets of grid points or elements as panels for panel participation output for a frequency response analysis of a coupled fluid-structural model.
| PANEL | NAME1 | SID1 | NAME2 | SID2 | NAME3 | SID3 | NAME4 | SID4 |
| NAME# | Panel label. No default (Character string) |
| SID# | Set identification number
for a set of grids or elements. No default (Integer > 0) |
- If a set of elements is defined, the panel will consist of all grid points connected to these elements.
