PARAM
Bulk Data Entry Defines values for parameters used during analysis and optimization.
| PARAM | N | V |
| PARAM | COUPMASS | YES |
- Field
- Contents
- N
- Name of Parameter.
- V
- Value of Parameter.
- This card is represented as a control card in HyperMesh.
- The available parameters and their descriptions are listed below (click the parameter name for parameter value).
