PARAM, GFL
Bulk Data Entry Specifies the uniform fluid damping coefficient for dynamic analyses.
| Parameter | Values | Description |
| GFL | <Real> Default = 0.0 |
GFL
specifies the uniform fluid damping coefficient in the formulation
of dynamics problems. To obtain the value for the parameter
GFL, multiply the critical damping ration,
, by 2.0. In coupled fluid-structure models, PARAM, G is applied to structural portion and PARAM, GFL to the fluid portion. |
- PARAM, GFL should be used to replace the GE field on Fluid Material entries (MATx) instead of PARAM, GE_MOD.
