PARAM, UCORD
Bulk Data Entry Specifies the coordinate system in which the mass moment of inertia is output. It also can be used to control the point about which the mass moment of inertia is calculated.
| Parameter | Values | Description |
| UCORD | <CID> Integer ≥ -1 |
PARAM,UCORD controls the calculation of mass
related properties like mass moment of inertia and center of
gravity. It controls both output from
PARAM,GRDPNT and
OUTPUT,MASSPROP. It also
affects the values of these properties when they are used in the
solution (both for analysis and optimization). Therefore, for
optimization with center of gravity and moment of inertia responses,
they will be affected by PARAM,UCORD.
- If PARAM, UCORD is not specified, CID = -1, or CID given is not found, all values in PARAM, GRDPNT are calculated relative to the basic coordinate system.
- If PARAM,UCORD is not specified, or CID given is not found, the center of gravity is output in the basic coordinate system and the related mass properties are calculated with respect to the center of gravity. This applies for these values which are used in the solution and for OUTPUT,MASSPROP.
- If PARAM, GRDPNT is not specified in the input deck, then the center of gravity and moment of inertia are not output regardless of the value of PARAM, UCORD.
- The values of PARAM, GRDPNT does not affect the output of Center of Gravity and Mass Moment of Inertia output via OUTPUT, MASSPROP.
