.pret file
The .pret file is an OptiStruct ASCII format results file.
File Creation
Creation of this file is controlled by the PRETBOLT I/O Options Entry.
File Contents
| Result | Description |
| Pretension force/adjustment | Pretension force/adjustment values for pretension bolts in pretensioning and pretensioned subcases. |
File Format
The file is sorted by iteration. Output from each iteration starts in the following
format:
| PRETENSION FORCE/ADJUSTMENT VALUES ON THE PRENTESION SECTIONS | ||||||||||
| ITERATION | Iteration_number | |||||||||
Where:
| Each iteration section contains the force/adjustment values for each pretension bolt in each static subcase. Each such subcase section is given the following header: | ||||||||||
| Subcase | Subcase_id | Subcase_label | ||||||||
Where:
| Pretension force/adjustment information is then provided, for each bolt, in the following format: | ||||||||||
| Pretension section ID (PRETENS #) | Force-incr | Adjust-incr | Force-tot | Adjust-tot | ||||||
Where:
- The I/O Option Previously Supported Results controls the frequency of output for analytical results during an optimization.
