PTADJST
Bulk Data Entry Defines the adjustment (shortening) on a pretension section.
| PTADJST | PSID | SID | ADJ |
| PTADJST | 3 | 5 | 0.5 |
| PSID | Pretensioning load set
identification number. (Integer > 0) |
| SID | Pretension section
| ADJ | Adjustment applied on this
section (positive value means shortening). 2 (Real) |
- PTADJST can be referred by PTADD or by the PRETENSION command in the subcase directly.
- Pretensioning adjustment shortens the pretensioned bolt by "removing" the set amount of material. This represents the effect of turning the nut by a set distance (number of turns).
- Pretensioning adjustment using PTADJST can also be used to define additional shortening to a pre-tensioned section. Therefore, when adjustment is applied to a section that has already been pre-tensioned, the final effect will be a sum of the status reached in the preceding pre-tensioning subcase plus the amount of adjustment through PTADJST.
