PTFORC1
Bulk Data Entry Defines pretensioning force on a set of pretension sections.
| PTFORC1 | PSID | F | SID1 | SID2 | SID3 | SID4 | SID5 | SID6 | |
| SID7 | SID8 | SID9 | etc. |
| PTFORC1 | 3 | 500.0 | 1 | 3 | 4 |
| PSID | Pretensioning load set
identification number. (Integer > 0) |
| F | Pretensioning force
applied on this set of sections. (Positive value creates tension).
2 (Real) |
| SIDi | Pretension section
- PTFORC1 can be referred by PTADD or by the PRETENSION command in the subcase directly.
- Pretensioning force is actually a pair of forces, applied to the opposite sides of the pretension section. This represents the effect of tightening the nut by a set longitudinal force (which is related to the applied torque).
