PTUBE
Bulk Data Entry Defines the properties of a thin-walled cylindrical tube element, referenced by a CTUBE entry.
| PTUBE | PID | MID | OD | T | NSM | OD2 |
| PTUBE | 2 | 6 | 6.29 | 0.25 |
| PID | Unique property identification number. (Integer > 0) |
| MID | Material identification number. (Integer > 0) |
| OD | Outside diameter of tube. (Real > 0.0) |
| T | Thickness of tube.
(Real; T ≤ ½ OD) |
| NSM | Nonstructural mass per unit
length. (Real) |
| OD2 | Diameter of tube at second grid point - G2 on
CTUBE entry. 2 Default = OD (OD or blank) |
