PVISC
Bulk Data Entry Defines properties of a one-dimensional viscous damping element (CVISC entry).
| PVISC | PID1 | CE1 | CR1 | PID2 | CE2 | CR2 |
| PVISC | 3 | 6.2 | 3.94 |
| PID# | Property identification number. No default (Integer > 0) |
| CE1, CE2 | Viscous damping values for extension in units of
force per unit velocity. No default (Real) |
| CR1, CR2 | Viscous damping values for rotation in units of
- Viscous properties are material independent; in particular, they are temperature independent.
- One or two viscous element properties may be defined on a single entry.
- This card is represented as a property in HyperMesh.
