QBDYLIB
Bulk Data Entry Defines the external function to be called to calculate time and temperature-dependent Uniform Heat Flux values.
| QBDYLIB | SID | GROUP | FUNCT |
Definition
| SID | Load set identification number that matches the
identification number on the QBDY1
entry. No default (Integer > 0) |
| GROUP | Defines the shared/dynamic library to be used. It refers to an existing LOADLIB entry in the input deck. No default (Character) |
| FUNCT | Defines the external function to be used. No default (Character) |
- The load set identification number (SID) must match the corresponding identification number on the QBDY1 entry.
