RANDOM
Subcase Information Entry Selects the RANDPS and RANDT1 Bulk Data Entries to be used in Random Response Analysis.
RANDOM = n
RANDOM = 177
| Argument | Options | Description |
| n | (Integer > 0) | The
RANDOM Subcase Information Entry can directly
reference the identification number of RANDPS and RANDT1 Bulk Data
Entries. 1 The RANDOM Subcase Information Entry can also reference a SET I/O Options Entry. This SET I/O Options Entry should reference a list of RANDPS/RANDT1 Bulk Data Entries. 2 |
- If the RANDOM Subcase
Entry is pointing directly to a RANDPS entry, then it is
subcase dependent. A separate subcase can be used to define Random Response
Analysis with the optional ANALYSIS=RANDOM
entry. If such a RANDOM entry is instead defined in the
global subcase section (above the first subcase), then OptiStruct will internally create a
RANDOM subcase with
ANALYSIS=RANDOM.Example: RANDOM entry pointing to RANDPS ID from Global Subcase
RANDOM = 334 SUBCASE 1 … BEGIN BULK RANDPS, 334, …Example: RANDOM entry pointing to RANDPS ID from within Random SubcaseSUBCASE 1 … SUBCASE 2 ANALYSIS=RANDOM RANDOM=334 BEGIN BULK RANDPS, 334, … - If the RANDOM
Subcase Information Entry is pointing to a SET I/O Entry,
then it should not be defined within any subcase and should only be specified in
the global subcase section (above the first subcase). For this, OptiStruct will internally create multiple
RANDOM subcases with
ANALYSIS=RANDOM (as many subcases are
internally created as RANDPS entries referenced on the
SET I/O Entry).When the RANDOM Subcase Entry is pointing to a SET of RANDPS IDs, then the random results are output separately for each RANDPS entry within the SET.Note: If the SET I/O Entry and RANDPS Bulk Data Entry have the same ID number, then OptiStruct selects the RANDPS Bulk Data Entry in this case and the SET I/O Entry is ignored.Example: RANDOM entry in Global Subcase pointing to SET ID referencing RANDPS IDs
SET 455 = 334, 335, 336 RANDOM = 455 SUBCASE 1 … BEGIN BULK RANDPS, 334, … RANDPS, 335, … RANDPS, 336, …
