RESPRINT
I/O Options and Subcase Information Entry The RESPRINT command can be used in the I/O Options section to force all unretained responses of a certain type to be printed to the output file, provided they are referenced either as an objective or a constraint. This also applies to manufacturing constraints for composites.
RESPRINT = option
| Argument | Options | Description |
| option | <MASS,
VOLUME, DISP,
BUCK, STRESS,
FREQ, EQUA,
EXTERNAL, WCOMP,
WFREQ, COMB,
COMP, STRAIN,
FORCE, COG,
INERTIA, MANUF,
BEADFRAC, ALL> No default |
- When a RESPRINT command is not present, only retained responses will be output.
- The arguments may be placed on a single card in a
comma-separated list. The following example will force all stress and displacement responses referenced as either an objective or constraint to be output.
RESPRINT = STRESS, DISP
