RESTART
I/O Options and Subcase Information Entry The RESTART command can be used in the I/O Options section to indicate that the current optimization is to be restarted from the final iteration of a previous optimization.
RESTART = option
| Argument | Options | Description |
| option | <File prefix> Default = prefix of .fem file |
- To restart an optimization, information about the final iteration of a previous optimization run is needed. This information is contained in the .sh file.
- The restart functionality allows unconverged optimization runs or optimization runs that were terminated before completion (due to a power outage, machine crash, etc.), to be restarted. You may also begin a new topology optimization from a previous optimization run with modified mesh or configuration by using the topology advanced restart feature. Refer to Requirements for Restarting in the User Guide.
- This I/O Option is not valid for analysis mode.
- Output files from a restart run are appended with the extension _rst#, where # is a 3 digit number indicating the starting iteration for the restart run. For example, filename_rst030.out is the .out file created when restarting filename.fem from iteration 30.
- The total length of information on this card is limited to 200 characters (including the card name and spaces between arguments). This data can be on a single line or span multiple continuation lines. Refer to I/O Options and Subcase Information Entries Guidelines for an example showing how to enter long file names on multiple lines.
