RGYRO
Bulk Data Entry Includes data required to perform Rotor Dynamics analysis in Modal Frequency Response Analysis and/or Modal Complex Eigenvalue Analysis. The RGYRO Bulk Data Entry is referenced by a corresponding RGYRO Subcase Information Entry in a specific subcase.
| RGYRO | RID | SYNCFLG | REFROTR | SPDUNIT | SPDLOW | SPDHIGH | SPEED |
| RGYRO | 14 | ASYNC | 3 | FREQ | 55 |
| RID | <INTEGER>
| SYNCFLG |
No default |
| REFROTR |
No default <INTEGER > 0> |
| SPDUNIT |
No default |
| SPDLOW | Minimum rotor speed for synchronous analysis. Default = 0.0 <Real> |
| SPDHIGH | Maximum rotor speed for synchronous analysis. Default = 99999.0 <Real> |
| SPEED |
Default = 0 <INTEGER, Real> |
- Multiple RGYRO Bulk Data Entries with the same RID cannot exist.
- The values entered on some optional fields
of the RGYRO Bulk Data Entry depend on factors such as: solution
sequence used, type of analysis performed, and the value of specific parameters. The
following table shows some of the optional fields and their relevance based on the
listed factors. Synchronous analysis is performed when the rotor speed is equal to
the modal frequency (Complex Eigenvalue Analysis) or the frequency of the forcing
function (Frequency Response Analysis) and Asynchronous analysis is performed when
the user-specified rotor speed is used for the analysis.
Solution Sequence Synchronous/Asynchronous Analysis Required Entry PARAM, GYROAVG Comment Modal Frequency Response Analysis Synchronous None 0 - Synchronous SPDLOW, SPDHIGH -1 3, 4 Asynchronous SPEED 0 - Asynchronous SPEED -1 4 Modal Complex Eigenvalue Analysis Synchronous SPDLOW, SPDHIGH - 3, 4 Asynchronous SPEED - 4 - When multiple rotors are present
within the system being modeled, one of the rotors is chosen as a reference rotor.
The speeds of the rest of the rotors are linearly dependent of the reference rotor.
Scale factors S1 and S2 are used to relate the
speeds.Where,
- Ω
- Speed of a rotor (different from the reference rotor)
- S1 and S2
- Scale factors
- Ωref
- Speed of the reference rotor
The scale factors S1 and S2 will be calculated by a least-mean-square fit of the relative rotor speeds specified on the RSPINR entries (between SPDLOW to SPDHIGH of the reference rotor). If the SPDLOW or SPDHIGH values are beyond the range specified on the RSPINR entry, the values will be extrapolated from the RSPINR entry values.
- PARAM, WR3 and PARAM, WR4 are necessary for rotor damping.
