RSPEC
Subcase Information Entry The RSPEC command can be used to reference combination rules, excitation degrees-of-freedom, and input spectra for use in response spectrum analysis.
RSPEC = option
| Argument | Options | Description |
| option | <SID> No default |
- Only valid in a response spectrum analysis subcase.
- Pre-loading is supported for Response Spectrum analysis subcases. STATSUB(PRELOAD) can be defined to identify the subcase used to apply pre-loading.
- Refer to Response Spectrum Analysis in the User Guide for more details.
