SECSET1
Bulk Data Entry Defines free boundary degrees-of-freedom to be free for use in One-Step Superelement Analysis (Alternate Format).
| SECSET1 | SEID | C | G1 | G2 | G3 | G4 | G5 | G6 | |
| G7 | G8 | etc |
Alternate Format
| SECSET1 | SEID | C | G1 | THRU | G2 |
| SECSET1 | 12 | 346 | 3 | 33 | 1 | 55 | 67 | 893 | |
| 12 | 982 |
| SEID | Superelement identification number. No default (Integer ≥ 0) |
| C | Component numbers. (Integer zero or blank for scalar points, or up to six unique digits (0 < digit ≤ 6) may be placed in the field with no embedded blanks for grid points. The components refer to the coordinate system referenced by the grid points.) |
| Gi | Grid or Scalar Point identification
numbers. Default = Blank (Integer > 0, or THRU) |
- If THRU option is used, then G1 should be less than G2.
