SET3
Bulk Data Entry Defines a set of grids or elements.
| SET3 | SID | TYPE | ID1 | ID2 | ID3 | ID4 | ID5 | ID6 | |
| ID7 | ID8 | etc. |
Example 1
| SET3 | 1 | PROP | 11 | 12 | 13 | 15 | 18 | 21 |
Alternate Format and Example
| SET3 | SID | TYPE | ID1 | "THRU" | ID2 | ||||
| SET3 | 33 | GRID | 20 | THRU | 60 |
| SID | Unique identification number. (Integer > 0) |
| TYPE | Set
type.
(Character) |
| IDi | Identifiers of grid points, elements, or
properties. (Integer > 0) |
