STEADY
Bulk Data Entry Defines the combination of frequency response and linear static subcases used for steady state analysis.
| STEADY | ID | NSTEPS | TTIME | ||||||
| + | SUBID1 | FREQ | SCALE | DPHASE | |||||
| + | SUBID2 | FREQ | SCALE | DPHASE | |||||
| + | etc. |
| STEADY | 10 | ||||||||
| 11 | 10.0 | ||||||||
| 12 |
| ID | Identification number of the
STEADY Bulk Data Entry. No default (Integer > 0) |
| NSTEPS | Number of time steps for the conversion
in time domain. Default = Total time*Maximum frequency*24 (Integer > 0, or blank) |
| TTIME | Total time for the conversion in time
domain. Default = 1.0/<minimum loading frequency> (Real or Blank) |
| SUBIDi | Index of subcase. 2 No default (Integer > 0) |
| FREQ | The frequency of a frequency response
subcase used for steady state analysis. 3 Default = Blank (Real or blank) |
| SCALE | Scaling factor for the displacements in
each subcase. Default = 1.0 (Real or blank) |
| DPHASE | Phase lead for the displacements in
each frequency response subcase. Default = 0.0 (Real or blank) |
- This entry is referenced in the subcase section using the STEADY Subcase Information Entry. The ANALYSIS Subcase Information Entry can be set to STEADY for the steady-state analysis subcase.
- Subcase type could be either direct or modal frequency response analysis or linear static analysis.
- If FREQ is specified, only the results of certain frequencies are used for conversion. If FREQ is blank, the results of all the frequencies are used for conversion. FREQ should be blank for linear static subcases.
- Steady state analysis subcases are supported for fatigue analysis. The LCID field of the FATLOAD Bulk Data Entry can point to the subcase ID of a steady state analysis subcase.
- The following results are
currently supported for Steady State subcases:
- Displacement
- Stress
- Equivalent Radiated Power (ERP). For ERP in steady-state analysis, note that Frequency-dependent ERPRLF with TABLEDi in PANELG is not supported.
- Acoustic Pressure, including pressure results from Infinite Elements (IE) and Adaptive Perfectly Matched Layer (APML).
- Element Forces.
