SUPORT1
Subcase Information Entry The SUPORT1 command can be used to select a fictitious support set to be applied to the model.
SUPORT1 = option
| Argument | Options | Description |
| option | <SID> No default |
- SUPORT1 Bulk Data Entries will be used only if selected in the Subcase Information section by the SUPORT1 Subcase Information Entry.
- The SUPORT1 Bulk Data Entry selected by the SUPORT1 Subcase Information Entry will be applied in all subcases.
