Pattern Grouping Options
There are over 70 pattern grouping options and variations available for topography optimization.
A summary of the major categories:
| Variable grouping pattern | Pattern Option | Type # | Required Vector Definitions | Description |
| None | - | 0 | - | Variables grouped as points. |
| One plane symmetry | - | 10 | One | Reflection of variables across one plane normal to first vector. |
| Two plane symmetry | - | 20 | Two | Reflection of variables across two planes, one normal to the first vector and one normal to second vector. |
| Three plane symmetry | - | 30 | Two | Reflection of variables across three planes, one normal to first vector, one normal to the second vector and one perpendicular to both vectors. |
| Linear | - | 1 | One | Variables grouped as lines extending in direction of first vector. |
| +1 plane | 21 | Two | Reflection of variables across one plane normal to second vector. | |
| +2 planes | 31 | Two | Reflection of variables across two planes, one normal to second vector and one perpendicular to both vectors. | |
| Circular | - | 2 | One | Variables grouped as circles around anchor node lying in a plane normal to first vector. |
| +1 plane | 12 | One | Reflection of variables across one plane normal to first vector. | |
| Planar | - | 3 | One | Variables grouped as planes extending normal to first vector. |
| +1 plane | 13 | One | Reflection of planes across plane normal to first vector. | |
| Radial 2D | - | 4 | One | Variables grouped as rays extending radially and normal to first vector. |
| +1 plane | 14 | One | Reflection of rays across plane normal to first vector. | |
| +2 planes | 24 | Two | Reflection of rays across two planes, one normal to the first vector and one normal to second vector. | |
| +3 planes | 34 | Two | Reflection of rays across three planes, one normal to first vector, one normal to the second vector and one perpendicular to both vectors. | |
| Cylindrical | - | 5 | One | Variables grouped as endless cylinders extending along and centered around first vector. |
| Radial 2D & Linear | - | 6 | One | Variables grouped as a combination of radial and linear patterns. |
| +1 plane | 26 | Two | Reflection of radial planes across plane normal to second vector. | |
| +2 planes | 36 | Two | Reflection of radial planes across plane normal to both first and second vectors. | |
| Radial 3D | - | 7 | - | Variables grouped as rays extending radially outward from anchor node. |
| +1 plane | 17 | One | Reflection of rays across plane normal to first vector. | |
| +2 planes | 27 | Two | Reflection of rays across two planes, one normal to the first vector and one normal to second vector. | |
| +3 planes | 37 | Two | Reflection of rays across three planes, one normal to first vector, one normal to the second vector and one perpendicular to both vectors. | |
| Vector defined | - | 8 | - | Variables grouped along vectors defined by the draw vectors of the individual nodes. |
| +1 plane | 18 | One | Reflection of variables across plane normal to first vector. | |
| +2 planes | 28 | Two | Reflection of variables across two planes, one normal to the first vector and one normal to second vector. | |
| +3 planes | 38 | Two | Reflection of variables across three planes, one normal to first vector, one normal to the second vector and one perpendicular to both vectors. | |
| Cyclical 1 | - | 40,41 | Two | Cyclical repetition of variables about axis defined by first vector. |
| +1 plane | 50,51 | Two | Reflection of variables across one plane normal to first vector. | |
| + linear | 60,61 | Two | Cyclically repeated variables grouped as lines extending in direction of first vector. | |
| + radial | 70,71 | Two | Cyclically repeated variables grouped as rays extending radially and normal to first vector. | |
| + radial & linear | 80,81 | Two | Cyclically repeated variables grouped as a combination of radial and linear patterns. |
These options can be used with shell and solid models to create reinforcement
patterns that obey manufacturing constraints and which conform to the shapes of the
parts. Examples of pattern grouping options are given in the following sections:
- Cross-section Optimization of a Spot Welded Tube
- Optimization of the Modal Frequencies of a Disc Using Constrained Beading Patterns
- Multi-plane Symmetric Reinforcement Optimization for a Pressure Vessel
- Shape Optimization of a Stamped Hat Section
- Shape Optimization of a Solid Control Arm
- Using Topography Optimization to Forge a Design Concept Out of a Solid Block
1 For
cyclical symmetry, the UCYC parameter (field 30) controls the number of
repetitions (and thus the repetition angle) for the cycles. If the TYP option
selected for cyclical symmetry is 40, 50, 60, 70, or 80, the cyclical repetition
pattern will be non-reflective. If the TYP option selected for cyclical symmetry
is 41, 51, 61, 71, or 81, the cyclical repetition pattern will be
reflective.
