WEIGHT
Subcase Information Entry The WEIGHT command can be used to define a weighting factor (multiplier) for the compliances of individual linear static solution subcases, which are used in the calculation of the "weighted compliance" and "combined compliance index" optimization responses.
WEIGHT = value
| Argument | Description |
| value | The multiplier to be used
for the compliance of this subcase in the calculation of "weighted
compliance" or "combined compliance index." Default = 0.0 (Real) |
- Refer to Responses in the User Guide for more information on "weighted compliance" and "combined compliance index" optimization response calculations.
- WEIGHT is only used in conjunction with DRESP1, RTYPE = WCOMP, COMB.
- If a WEIGHT is not defined in any subcase, but a DRESP1 with RTYPE = WCOMP or COMB exists, all static subcases are assigned a WEIGHT of 1.0 by default.
- DRESP1, RTYPE=WCOMP is supported for ESL-Nonlinear Response Optimization.
- This entry is represented as an optimization response in HyperMesh.
