YTITLE
I/O Options and Subcase Information Entry The YTITLE command can be used in the I/O Options section to define the y-axis label for XYPUNCH or XYPLOT output from a Random Response Analysis.
YTITLE = title
| Argument | Description |
| title | Character
string. Default = blank |
- YTITLE may not be continued onto the next line.
- YTITLE definition applies to all plots
defined after YTITLE until another definition of
YTITLE occurs. The following example would assign
X-A,Y-Aand the default plot title to the first plot, thenX-A,Y-B, andC-Ato the second plot.XTITLE = X-A YTITLE = Y-A XYPLOT (first plot definition) YTITLE = Y-B TCURVE = C-A XYPLOT (second plot definition)
