Create Link Attachments to FE Absorb Connectors
If you have an existing mesh but no connector, you can create connectors and attachments by selecting the mesh manually and defining the control type, or automatically where HyperMesh finds any mesh that matches the control type.
From the Connectors ribbon, Connect Attachments tool group, click the
FE Absorb Connectors tool.
Click
on the guide bar to choose a
detection method and enter a tolerance value
If set to Manual, use the selector to choose elements. -
Select an attachment control type from the drop-down menu.
If you select Undefined, the connector will be created without a control.
On the guide bar, complete one of the following:
- Click
to apply and stay in the tool. - Click
to apply and close the tool. - Click
to exit the tool without applying.
- Click
