ASET1
Bulk Data Entry Defines the boundary degrees-of-freedom of a superelement assembly for matrix reduction.
| ASET1 | C | G1 | G2 | G3 | G4 | G5 | G6 | G7 | |
| G8 | G9 | G10 | etc. |
| ASET1 | 123 | 34 | 88 | 4 | 12 | 19 | 7 | 70 | |
| 1234 | 65 |
Alternate Format and Example
| ASET1 | C | G1 | "THRU" | G2 | |||||
| ASET1 | 123456 | 88 | THRU | 207 |
| C | Component
                                    number. (Integer zero or blank for scalar points, or up to 6 unique digits (0 < integer ≤ 6) may be placed in the field with no embedded blanks for grid points. The components refer to the coordinate system referenced by the grid points.) | |
| Gi | Grid or scalar point
                                identification numbers. (Integer > 0, for THRU option, G1 < G2) |
- If the alternate format is used, all points in the sequence G1 through G2 are not required to exist, but there must be at least one boundary degree-of-freedom for the model, or a fatal error will result. Any grids implied in the THRU that do not exist will collectively produce a warning message, but will otherwise be ignored.
- Refer to Direct Matrix Input in the User Guide for more information on the use of this card.
- A fatal error will be issued if the input contains ASET or ASET1, but PARAM,EXTOUT is not given.
- When the SPSYNTAX setting on the SYSSETTING I/O Option is set to CHECK (default) or MIXED, it is allowed that when grid lists are provided for a given component, that the grid references be either scalar points (SPOINT) or structural grid points (GRID) when the component is 0, 1 or blank; interpreting all of these as 0 for scalar points and as 1 for structural grids. When SPSYNTAX is set to STRICT it is required for grid/component pairs (G#/C#) that the component be 0 or blank when the grid references are to scalar points (SPOINT), and that the component be > 1 when the grid references are to structural grid points (GRID). When the component is greater than 1, the grid references must always be a structural grid (GRID).
- This card is represented as a constraint load in HyperMesh.
