CMBEAM
Bulk Data Entry Defines a beam element for multibody dynamics solution sequence without reference to a property entry.
CMBEAM EID MID GA GB X1, G0 Y1 Z1 L
A I1 I2 J K K
CMBEAM 1 2 123 125 0.0 0.0 1.0 5.0
100.0 833.3 833.3 1485.3
EID Unique element identification number.
(Integer > 0)
MID Material identification number.
Only MAT1 material definitions may be referenced by this element.
(Integer > 0)
GA, GB Grid point identification number of connection points.
(Integer > 0; GA ≠ GB)
X1, Y1, Z1 Components of vector v at end A, measured at end A, parallel to the components of the displacement coordinate system for GA, to determine (with the vector from end A to end B) the orientation of the element coordinate system for the BEAM element.
(Real)
G0 Grid point identification number to optionally supply X1, X2, and X3 (Integer > 0). Direction of orientation vector is GA to G0.
(Integer > 0)
L Undeformed length along the X-axis of the beam.
(Real)
A Area of the beam cross-section.
No default (Real > 0.0)
I1 Area moment inertia in plane 1 about the neutral axis.
I2 Area moment inertia in plane 2 about the neutral axis.
J Torsional constant.
(Real > 0.0)
K, K Area factor for shear.
Default = 0.0 (Real)
  1. The X-axis of the beam is always along the line connecting G1 and G2. The Z-axis of the beam is determined based on the X-axis and the Y-axis provided by G3/X1, Y1, and Z1.
  2. The moments of inertia are defined as:
    | 1 = / z z = ∫ y 2 d A | 2 = / y y = ∫ Z 2 dA
    The beam coordinates must be aligned with the principal axes of the cross-section.
  3. The transverse shear stiffness in planes 1 and 2 are (K1)AG and (K2)AG, respectively. If a value of 0.0 is used for K1 and K2, the transverse shear flexibilities are set to 0.0 (K1 and K2 are interpreted as infinite).
  4. This card is represented as a bar2 element in HyperMesh.
