CQAXI
Bulk Data Entry Defines a 2D axisymmetric quadrilateral cross-section ring element.
CQAXI EID PID G1 G2 G3 G4 G5 G6
G7 G8 Theta
CQAXI 111 2 31 74 75 32 51 52
63 62 15.0
EID Unique element identification number.
No default (Integer > 0)
PID A PAXI entry identification number.
Default = EID (Integer > 0)
GI Identification numbers of connected corner grid points.
Corner grid points cannot be omitted.
No default (Integers > 0, all unique)
Theta Material orientation angle in degrees.
Default = 0.0 (Real)
  1. Element identification numbers must be unique with respect to all other element identification numbers.
  2. The element grids numbering scheme is controlled by SYSSETTING,AXEGORD,0/1.
    SYSSETTING,AXEGORD Corner Grid Points Edge Grid Points
    C C C C E E E E
    0 (default) G1 G3 G5 G7 G2 G4 G6 G8
    1 G1 G2 G3 G4 G5 G6 G7 G8
  3. All the grid points must be in the x-y plane or in the x-z plane of the basic coordinate system with x = r ≥ 0.
    Corner grid points C, C, C and C must be present. The edge points E, E, E and E are optional. If any of the edge points are present, they all must be used.
    Note that this information is consistent only for the default SYSSETTING,AXEGORD,0. If this is switched to 1, then the corresponding grid point references should be interpreted accordingly.
    Figure 1. CQAXI Definition
  4. The continuation line is optional.
  5. If the PAXI entry referenced in field 3 references a MAT3 entry, material properties and stresses are always given in the (xm, ym) or (xm, zm) coordinate system shown in Figure 1.
  6. A concentrated load (for example, the load specified on a FORCE entry) at a grid Gi of this element denotes that applied onto the circumference with radius of Gi. For example, in order to apply a load of 200N/m on the circumference at Gi which is located at a radius of 0.4m, the magnitude of the load specified on the static load entry must be:
    200N/m   *   2π   *   0 .4m   =   502 .655N MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaebbnrfifHhDYfgasaacH8srps0l bbf9q8WrFfeuY=Hhbbf9v8qqaqFr0xc9pk0xbba9q8WqFfea0=yr0R Yxir=Jbba9q8aq0=yq=He9q8qqQ8frFve9Fve9Ff0dmeaabaqaciGa caGaaeqabaqaceaadaaakeaadaqadaqaaiaajkdacaqIWaGaaKimai aaj6eacaqIVaGaaKyBaaGaayjkaiaawMcaaiaaykW7caqIQaGaaGPa VlaajkdacaqIapGaaGPaVlaajQcacaaMc8+aaeWaaeaacaqIWaGaaK OlaiaajsdacaqITbaacaGLOaGaayzkaaGaaGPaVlaaj2dacaaMc8Ua aKynaiaajcdacaqIYaGaaKOlaiaajAdacaqI1aGaaKynaiaaj6eaaa a@503E@
  7. Axisymmetric elements are supported only for Linear Static, Nonlinear Static (small and large displacement) and Heat Transfer (linear and non-linear, steady-state, and transient) Analysis. Currently, axisymmetric elements are not supported for Inertia Relief Analysis in Large Displacement Nonlinear Analysis.
  8. Axisymmetric elements are supported only for size optimization (only material property – DVMREL1, DVMREL2) and shape optimization, using stress responses. Refer to DRESP1 - Static Stress/Strain Item Codes for more details.
  9. PARAM,AXI2DTOR,YES can be used to convert 2D axisymmetric elements CQAXI and CTAXI in the model to general axisymmetric elements CQAXIG and CTAXIG, respectively, while PAXI is considered as PAXIG, which allows the elements to have torsional deformation about the axis-of-symmetry.
    Note: With this option, the elements may need additional constraints in the out-of-plane direction to eliminate rigid body motions. Currently this option is supported only for linear analyses (including static, dynamic and preloading analyses).
