DVMBRL2
Bulk Data Entry Relates a design variable to properties of MBD entities using a relationship defined by a DEQATN card. The equation inputs come from the referenced DESVAR values and the constants defined on the DTABLE card.
| DVMBRL2 | ID | PTYPE | BID/ EID | PNAME | EQID | ||||
| DESVAR | DVID1 | DVID2 | DVID3 | DVID4 | DVID5 | DVID6 | DVID7 | ||
| DVID8 | DVID9 | etc. | |||||||
| DTABLE | LABL1 | LABL2 | LABL3 | LABL4 | LABL5 | LABL6 | LABL7 | ||
| LABL8 | etc. |
| ID | Relationship identity. ID
                                must be unique with respect to other DVMBRL1 and
                                    DVMBRL2 cards. No default (Integer > 0) | |
| TYPE | Property type to be
                                related. 1 No default (Character) | |
| BID/EID | Body ID or Element ID
                                number. When TYPE is PRBODY,
                                this field is the ID number of a rigid body. When
                                    TYPE is CMBUSH(M),
                                    CMBEAM(M), or CMSPDP(m), this
                                field is the ID number of a corresponding element. No default (Integer > 0) | |
| PNAME | Property name, such as "A"
                                or "L" (as in the documentation of the PRBODY,
                                    CMBEAM(M), CMBUSH(M), and
                                    CMSPDP(M) cards). No default (Character or Integer > 0) | |
| EQID | Equation ID of
                                    DEQATN data. No default (Integer > 0) | |
| DESVAR | Indicates DESVAR ID numbers follow. | |
| DVIDi | DESVAR
                                    ID. No default (Integer > 0) | |
| DTABLE | Indicates DTABLE labels follow. | |
| LABLi | Constant label on
                                    DTABLE card. No default (Character) |
- Property type table: - PRBODY
- IXX
- IYY
- IZZ
- IXY
- IXZ
- X
- X component of center of gravity.
- Y
- Y component of center of gravity.
- Z
- Z component of center of gravity.
 - CMBEAM/CMBEAMM
- L
- Undeformed length along the X-axis of the beam.
- A
- Area of the beam cross-section.
- I1
- Area moment of inertia in plane 1 about the neutral axis.
- I2
- J
- Torsional constant.
- K ~ K
- Area factor for shear.
 - CMBUSH/CMBUSHM
- K ~ K
- Translational stiffness.
- K ~ K
- Rotational stiffness.
- B ~ B
- Translational damping.
- B ~ B
- Rotational damping.
- P ~ P3
- Translational preload.
- P4 ~ P6
- Rotational preload.
 - CMSPDP/CMSPDPM
- K
- Stiffness
- B
- Damping
- L
- Unstretched length of spring damper.
- PF
- Preload force.
- This card is represented as an optimization design variable property relationship in HyperMesh.
