MATFVE
Bulk Data Entry Defines material properties for frequency-dependent viscoelastic materials.
Format 1 (TYPE=FORMULA)
MATFVE MID FORMULA
R1 I1 a R1k I1k b
Format 2 (TYPE=TABLE)
MATFVE MID TABLE
TID1 TID2 TID3 TID4
Format 3 (TYPE=PRONY)
MATFVE MID PRONY gD1 tD1 gB1 tB1
gD2 tD2 gD3 tD3 gD4 tD4 gD5 tD5
gB2 tB2 gB3 tB2 gB4 tB4 gB5 tB5
Format 4 (TYPE=PRELOAD)
MATFVE MID PRELOAD
EUNIAXI
El Es f ε
etc.
EVOLUME
Kl Ks f J
etc.
Format 5 (TYPE=RTEST)
Format for Separate Shear and Volumetric test data for relaxation:
MATFVE MID TYPE etol npmax
SHEAR slong
gs(t) t
etc
BULK blong
gk(t) t
etc
Format for Combined Shear and Volumetric test data for relaxation:
COMB slong blong
gs(t) gk(t) t
etc
Format 6 (TYPE=CTEST)
Format for Separate Shear and Volumetric test data for creep:
SHEAR slong
js(t) t
etc
BULK blong
jk(t) t
etc
Format for Combined Shear and Volumetric test data for creep:
COMB slong blong
js(t) jk(t) t
etc
MATFVE 2 PRONY 0.25 5e-2 0.25 5e-2
Definition
MID Unique material identification number.
No default (Integer > 0)
TYPE Frequency-dependent visco-elastic material model type.
FORMULA 4
TABLE 5
PRONY 6
PRELOAD 7
RTEST
CTEST
No default
R1 Real part of the deviatoric part for the FORMULA type.
Default = blank (Real)
I1 Imaginary part of the deviatoric part for the FORMULA type.
a A real number for the deviatoric part for the FORMULA type.
R1k Real part of the bulk part for the FORMULA type.
I1k Imaginary part of the bulk part for the FORMULA type.
b A real number for the bulk part for the FORMULA type.
TID1 Table ID (TABLEDi only) to specify the real part of the deviatoric part.
Default = blank (Integer > 0)
TID2 Table ID (TABLEDi only) to specify the Imaginary part of the deviatoric part.
TID3 Table ID (TABLEDi only) to specify the real part of the bulk part.
TID4 Table ID (TABLEDi only) to specify the Imaginary part of the bulk part.
Default = blank (Integer>0)
gDi Modulus ratio for the i MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbwvMCKf MBHbqefqvATv2CG4uz3bIuV1wyUbqedmvETj2BSbqefm0B1jxALjhi ov2DaebbnrfifHhDYfgasaacH8srps0lbbf9q8WrFfeuY=Hhbbf9v8 qqaqFr0xc9pk0xbba9q8WqFfea0=yr0RYxir=Jbba9q8aq0=yq=He9 q8qqQ8frFve9Fve9Ff0dmeaacaGacmGadaWaaiqacaabaiaafaaake aacaWGPbaaaa@39C5@ -th deviatoric Prony series.
No default (Real > 0.0)
tDi Relaxation time for the i MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbwvMCKf MBHbqefqvATv2CG4uz3bIuV1wyUbqedmvETj2BSbqefm0B1jxALjhi ov2DaebbnrfifHhDYfgasaacH8srps0lbbf9q8WrFfeuY=Hhbbf9v8 qqaqFr0xc9pk0xbba9q8WqFfea0=yr0RYxir=Jbba9q8aq0=yq=He9 q8qqQ8frFve9Fve9Ff0dmeaacaGacmGadaWaaiqacaabaiaafaaake aacaWGPbaaaa@39C5@ -th deviatoric Prony series.
gBi Modulus ratio for the i MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbwvMCKf MBHbqefqvATv2CG4uz3bIuV1wyUbqedmvETj2BSbqefm0B1jxALjhi ov2DaebbnrfifHhDYfgasaacH8srps0lbbf9q8WrFfeuY=Hhbbf9v8 qqaqFr0xc9pk0xbba9q8WqFfea0=yr0RYxir=Jbba9q8aq0=yq=He9 q8qqQ8frFve9Fve9Ff0dmeaacaGacmGadaWaaiqacaabaiaafaaake aacaWGPbaaaa@39C5@ -th bulk Prony series.
tBi Relaxation time for the i MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbwvMCKf MBHbqefqvATv2CG4uz3bIuV1wyUbqedmvETj2BSbqefm0B1jxALjhi ov2DaebbnrfifHhDYfgasaacH8srps0lbbf9q8WrFfeuY=Hhbbf9v8 qqaqFr0xc9pk0xbba9q8WqFfea0=yr0RYxir=Jbba9q8aq0=yq=He9 q8qqQ8frFve9Fve9Ff0dmeaacaGacmGadaWaaiqacaabaiaafaaake aacaWGPbaaaa@39C5@ -th bulk Prony series.
EUNIAXI Continuation line to indicate the storage and loss moduli from uniaxial tests when TYPE = PRELOAD.
EVOLUME Continuation line to indicate the storage and loss moduli from volumetric tests when TYPE = PRELOAD.
El Uniaxial loss modulus.
No default (Real)
Es Uniaxial storage modulus.
No default (Real)
f Frequency.
No default (Real ≥ 0.0)
ε Uniaxial nominal strain.
No default (Real)
Kl Bulk loss modulus.
No default (Real)
Ks Bulk storage modulus.
No default (Real)
J Volume ratio between current and original volumes.
SHEAR Continuation line to indicate test data from shear relaxation/creep tests are to follow.
BULK Continuation line to indicate test data from volumetric relaxation/creep tests are to follow.
COMB Continuation line to indicate test data from both shear and volumetric relaxation/creep tests are to follow.
t Time; should be specified in an ascending order.
gs(t) Normalized shear modulus.
No default (0.0 ≤ Real ≤ 1.0)
gk(t) Normalized bulk modulus.
js(t) Normalized shear compliance.
No default (1.0 ≤ Real)
jk(t) Normalized bulk compliance.
etol Error tolerance for CTEST/RTEST material calibration.
0.0
Implies that the tolerance is automatically controlled.
Default = 0.0 (0.0 ≤ Real)
npmax Maximum number of terms in the Prony series for CTEST/RTEST material calibration.
Default = 5 (1 ≤ Integer ≤ 5)
slong Long term normalized Shear modulus for RTEST.
Default = blank (0.0 < Real < 1.0)
Long term normalized Shear compliance for CTEST.
Default = blank (1.0 < Real)
blong Long term normalized Bulk modulus for RTEST.
Long term normalized Bulk compliance for CTEST.
  1. The long-term response is given by an elastic material description, which needs to have the same MID. MATHE/MAT1/MAT9 are supported.
  2. CHEXA, CTETRA, CPENTA, CPYRA elements are supported.
  3. A function g * ( t ) MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4zaiaacQ cadaqadaqaaiaadshaaiaawIcacaGLPaaaaaa@3A13@ of deviatoric relaxation in the time-domain is considered.
    If the MTIME field on MAT1/MAT9/MATHE entries is set to LONG (default), the input material property is considered as the long-term material deviatoric input modulus ( G ∞ MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4ramaaBa aaleaacqGHEisPaeqaaaaa@3860@ ) and Equation 1 is used for calculation of the material property incorporating relaxation.
    g * ( t ) = ∑ i G i G ∞ e − t τ i = ∑ i g i g ∞ e − t τ i MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4zaiaacQ cadaqadaqaaiaadshaaiaawIcacaGLPaaacqGH9aqpdaaeqbqaamaa laaabaGaam4ramaaBaaaleaacaWGPbaabeaaaOqaaiaadEeadaWgaa WcbaGaeyOhIukabeaaaaGccaWGLbWaaWbaaSqabeaacqGHsisldaWc aaqaaiaadshaaeaacqaHepaDdaWgaaadbaGaamyAaaqabaaaaaaaaS qaaiaadMgaaeqaniabggHiLdGccqGH9aqpdaaeqbqaamaalaaabaGa am4zamaaBaaaleaacaWGPbaabeaaaOqaaiaadEgadaWgaaWcbaGaey OhIukabeaaaaGccaWGLbWaaWbaaSqabeaacqGHsisldaWcaaqaaiaa dshaaeaacqaHepaDdaWgaaadbaGaamyAaaqabaaaaaaaaSqaaiaadM gaaeqaniabggHiLdaaaa@574B@
    The subscript i MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamyAaaaa@36E5@ indicates the i MathType@MTEF@5@5@+= feaagKart1ev2aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbwvMCKf MBHbqefqvATv2CG4uz3bIuV1wyUbqedmvETj2BSbqefm0B1jxALjhi ov2DaebbnrfifHhDYfgasaacH8srps0lbbf9q8WrFfeuY=Hhbbf9v8 qqaqFr0xc9pk0xbba9q8WqFfea0=yr0RYxir=Jbba9q8aq0=yq=He9 q8qqQ8frFve9Fve9Ff0dmeaacaGacmGadaWaaiqacaabaiaafaaake aacaWGPbaaaa@39C5@ -th term in the Prony series.
    This equation is equivalent to the equation on the MATVE entry. The equation on MATVE is rewritten by using:
    g ( t ) = g ∞ ( g * ( t ) + 1 ) MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4zamaabm aabaGaamiDaaGaayjkaiaawMcaaiabg2da9iaadEgadaWgaaWcbaGa eyOhIukabeaakmaabmaabaGaam4zaiaacQcadaqadaqaaiaadshaai aawIcacaGLPaaacqGHRaWkcaaIXaaacaGLOaGaayzkaaaaaa@4440@
    If the MTIME field on the MAT1/MAT9/MATHE entries is set to INSTANT, the input material property is considered as the instantaneous material input ( G 0 MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4ramaaBa aaleaacaaIWaaabeaaaaa@37A9@ ) and Equation 2 for g * ( t ) MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4zaiaacQ cadaqadaqaaiaadshaaiaawIcacaGLPaaaaaa@3A13@ can be rewritten by substituting g ∞ = 1 − ∑ i g i MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4zamaaBa aaleaacqGHEisPaeqaaOGaeyypa0JaaGymaiabgkHiTmaaqafabaGa am4zamaaBaaaleaacaWGPbaabeaaaeaacaWGPbaabeqdcqGHris5aa aa@4044@ for calculation of the material property incorporating relaxation.
    G ∞ = g ∞ * G 0 MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4ramaaBa aaleaacqGHEisPaeqaaOGaeyypa0Jaam4zamaaBaaaleaacqGHEisP aeqaaOGaaiOkaiaadEeadaWgaaWcbaGaaGimaaqabaaaaa@3E63@
    Long-term deviatoric modulus.
    Where, g ∞ MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4zamaaBa aaleaacqGHEisPaeqaaaaa@3880@ is the normalized long term deviatoric modulus.
    G i = g i * G 0 MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4ramaaBa aaleaacaWGPbaabeaakiabg2da9iaadEgadaWgaaWcbaGaamyAaaqa baGccaGGQaGaam4ramaaBaaaleaacaaIWaaabeaaaaa@3D5D@
    Prony series deviatoric parameter.
    Where, g i MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4zamaaBa aaleaacaWGPbaabeaaaaa@37FD@ are the Prony series deviatoric parameters.
    τ i
    Relaxation time.
    Where,
    g MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4zaaaa@36E3@
    Indicates the normalized modulus.
    G MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4zaaaa@36E3@
    Indicates the modulus for relaxation.
    j MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4zaaaa@36E3@
    Indicates the normalized compliance.
    J MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4zaaaa@36E3@
    Indicates the compliance for creep.
    See Comment 8.
    The example equations in this comment show the calculation for shear relaxation. These can be similarly written in an analogous manner for bulk relaxation.
    The Fourier transform of this g * ( t ) MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4zaiaacQ cadaqadaqaaiaadshaaiaawIcacaGLPaaaaaa@3A13@ function is:
    g ˜ * ( ω ) = F ( g * ( t ) ) = R + i I MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGabm4zayaaia GaaiOkamaabmaabaGaeqyYdChacaGLOaGaayzkaaGaeyypa0JaamOr amaabmaabaGaam4zaiaacQcadaqadaqaaiaadshaaiaawIcacaGLPa aaaiaawIcacaGLPaaacqGH9aqpcaWGsbGaey4kaSIaamyAaiaadMea aaa@46E7@
    Where, F MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOraaaa@36C2@ is the Fourier transformation. Equation 3 is for the frequency-dependent deviatoric relaxation. Similarly, the equation for the frequency-dependent bulk relaxation can be written in an analogous manner.
    k ˜ * ( ω ) = F ( k * ( t ) ) = R k + i I k MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGabm4Aayaaia GaaiOkamaabmaabaGaeqyYdChacaGLOaGaayzkaaGaeyypa0JaamOr amaabmaabaGaam4AaiaacQcadaqadaqaaiaadshaaiaawIcacaGLPa aaaiaawIcacaGLPaaacqGH9aqpcaWGsbWaaSbaaSqaaiaadUgaaeqa aOGaey4kaSIaamyAaiaadMeadaWgaaWcbaGaam4Aaaqabaaaaa@4931@
    After Fourier transformation, the Real and Imaginary parts R MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOraaaa@36C2@ , I MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOraaaa@36C2@ and R k MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOuamaaBa aaleaacaWGRbaabeaaaaa@37EA@ , I k MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOuamaaBa aaleaacaWGRbaabeaaaaa@37EA@ are frequency-dependent and can be input in four different ways (FORMULA, TABLE, PRONY, or PRELOAD).
  4. When TYPE=FORMULA:
    R = R 1 * f − a MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOuaiabg2 da9iaadkfacaaIXaGaaiOkaiaadAgadaahaaWcbeqaaiabgkHiTiaa dggaaaaaaa@3CFF@
    I = I 1 * f − a MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamysaiabg2 da9iaadMeacaaIXaGaaiOkaiaadAgadaahaaWcbeqaaiabgkHiTiaa dggaaaaaaa@3CED@
    R k = R 1 k * f − b MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOuamaaBa aaleaacaWGRbaabeaakiabg2da9iaadkfacaaIXaGaam4AaiaacQca caWGMbWaaWbaaSqabeaacqGHsislcaWGIbaaaaaa@3F16@
    I k = I 1 k * f − b MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOuamaaBa aaleaacaWGRbaabeaakiabg2da9iaadkfacaaIXaGaam4AaiaacQca caWGMbWaaWbaaSqabeaacqGHsislcaWGIbaaaaaa@3F16@
    Where,
    f MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOraaaa@36C2@
    Frequency.
    Real and imaginary parts of the Fourier transform of the deviatoric relaxation function.
    Real and imaginary parts of the Fourier transform of the bulk relaxation function.
  5. When TYPE=TABLE:
    TID1
    Specify ω R MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeqyYdCNaam Ouaaaa@389B@ as a function of the frequency f MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOraaaa@36C2@ .
    TID2
    Specify ω I MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeqyYdCNaam Ouaaaa@389B@ as a function of the frequency f MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOraaaa@36C2@ .
    TID3
    Specify ω R k MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeqyYdCNaam OuamaaBaaaleaacaWGRbaabeaaaaa@39B7@ as a function of the frequency f MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOraaaa@36C2@ .
    TID4
    Specify ω I k MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeqyYdCNaam OuamaaBaaaleaacaWGRbaabeaaaaa@39B7@ as a function of the frequency f MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOraaaa@36C2@ .
    Where,
    ω
    Angular frequency.
  6. When TYPE=PRONY, the data inputs have the same meaning as the MATVE card. The storage and loss moduli are determined as follows, after a Fourier transform of the time-domain Prony series.
    G s = ( G ∞ + ∑ i G i τ i 2 ω 2 1 + τ i 2 ω 2 ) MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4ramaaBa aaleaacaWGZbaabeaakiabg2da9maabmaabaGaam4ramaaBaaaleaa cqGHEisPaeqaaOGaey4kaSYaaabuaeaadaWcaaqaaiaadEeadaWgaa WcbaGaamyAaaqabaGccqaHepaDdaqhaaWcbaGaamyAaaqaaiaaikda aaGccqaHjpWDdaahaaWcbeqaaiaaikdaaaaakeaacaaIXaGaey4kaS IaeqiXdq3aa0baaSqaaiaadMgaaeaacaaIYaaaaOGaeqyYdC3aaWba aSqabeaacaaIYaaaaaaaaeaacaWGPbaabeqdcqGHris5aaGccaGLOa Gaayzkaaaaaa@5144@
    K s = ( K ∞ + ∑ i K i τ i 2 ω 2 1 + τ i 2 ω 2 ) MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4samaaBa aaleaacaWGZbaabeaakiabg2da9maabmaabaGaam4samaaBaaaleaa cqGHEisPaeqaaOGaey4kaSYaaabuaeaadaWcaaqaaiaadUeadaWgaa WcbaGaamyAaaqabaGccqaHepaDdaqhaaWcbaGaamyAaaqaaiaaikda aaGccqaHjpWDdaahaaWcbeqaaiaaikdaaaaakeaacaaIXaGaey4kaS IaeqiXdq3aa0baaSqaaiaadMgaaeaacaaIYaaaaOGaeqyYdC3aaWba aSqabeaacaaIYaaaaaaaaeaacaWGPbaabeqdcqGHris5aaGccaGLOa Gaayzkaaaaaa@5150@
    G l = ( ∑ i G i τ i ω 1 + τ i 2 ω 2 ) MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4ramaaBa aaleaacaWGSbaabeaakiabg2da9maabmaabaWaaabuaeaadaWcaaqa aiaadEeadaWgaaWcbaGaamyAaaqabaGccqaHepaDdaWgaaWcbaGaam yAaaqabaGccqaHjpWDaeaacaaIXaGaey4kaSIaeqiXdq3aa0baaSqa aiaadMgaaeaacaaIYaaaaOGaeqyYdC3aaWbaaSqabeaacaaIYaaaaa aaaeaacaWGPbaabeqdcqGHris5aaGccaGLOaGaayzkaaaaaa@4C38@
    K l = ( ∑ i K i τ i ω 1 + τ i 2 ω 2 ) MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4samaaBa aaleaacaWGSbaabeaakiabg2da9maabmaabaWaaabuaeaadaWcaaqa aiaadUeadaWgaaWcbaGaamyAaaqabaGccqaHepaDdaWgaaWcbaGaam yAaaqabaGccqaHjpWDaeaacaaIXaGaey4kaSIaeqiXdq3aa0baaSqa aiaadMgaaeaacaaIYaaaaOGaeqyYdC3aaWbaaSqabeaacaaIYaaaaa aaaeaacaWGPbaabeqdcqGHris5aaGccaGLOaGaayzkaaaaaa@4C40@
    Where,
    G s MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4ramaaBa aaleaacaWGZbaabeaaaaa@37E7@ , G l MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4ramaaBa aaleaacaWGSbaabeaaaaa@37E0@
    Deviatoric storage and loss moduli.
    K s MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4ramaaBa aaleaacaWGZbaabeaaaaa@37E7@ , K l MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4ramaaBa aaleaacaWGSbaabeaaaaa@37E0@
    Bulk storage and loss moduli.
    G ∞ MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4ramaaBa aaleaacqGHEisPaeqaaaaa@3860@ , K ∞ MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4ramaaBa aaleaacqGHEisPaeqaaaaa@3860@
    Long-term material modulus.
    G i = g i * G 0 MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4ramaaBa aaleaacaWGPbaabeaakiabg2da9iaadEgadaWgaaWcbaGaamyAaaqa baGccaGGQaGaam4ramaaBaaaleaacaaIWaaabeaaaaa@3D5D@ , K i = k i * K 0 MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4samaaBa aaleaacaWGPbaabeaakiabg2da9iaadUgadaWgaaWcbaGaamyAaaqa baGccaGGQaGaam4samaaBaaaleaacaaIWaaabeaaaaa@3D69@
    Where, g i MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4zamaaBa aaleaacaWGPbaabeaaaaa@37FD@ and k i MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4zamaaBa aaleaacaWGPbaabeaaaaa@37FD@ are Prony series parameters for shear and bulk moduli, respectively.
    τ i
    Relaxation time.
    ω
    Angular frequency.
    ωI=1− G s G ∞ MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeqyYdCNaam ysaiabg2da9iaaigdacqGHsisldaWcaaqaaiaadEeadaWgaaWcbaGa am4CaaqabaaakeaacaWGhbWaaSbaaSqaaiabg6HiLcqabaaaaaaa@3FB3@
    ωR= G l G ∞ MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeqyYdCNaam Ouaiabg2da9maalaaabaGaam4ramaaBaaaleaacaWGSbaabeaaaOqa aiaadEeadaWgaaWcbaGaeyOhIukabeaaaaaaaa@3E0D@
    ω I k =1− K s K ∞ MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeqyYdCNaam ysamaaBaaaleaacaWGRbaabeaakiabg2da9iaaigdacqGHsisldaWc aaqaaiaadUeadaWgaaWcbaGaam4CaaqabaaakeaacaWGlbWaaSbaaS qaaiabg6HiLcqabaaaaaaa@40E1@
    ω R k = K l K ∞ MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaeqyYdCNaam OuamaaBaaaleaacaWGRbaabeaakiabg2da9maalaaabaGaam4samaa BaaaleaacaWGSbaabeaaaOqaaiaadUeadaWgaaWcbaGaeyOhIukabe aaaaaaaa@3F3B@
    Where,
    ω
    Angular frequency.
  7. When TYPE= PRELOAD:
    EUNIAXI
    Test data to specify uniaxial loss modulus, uniaxial storage modulus, the frequency f MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOraaaa@36C2@ , uniaxial nominal strain.
    EVOLUME
    Test data to specify bulk loss modulus, bulk storage modulus, the frequency f MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamOraaaa@36C2@ , volume ratio (current volume/initial volume).
  8. When MODEL=RTEST/CTEST:
    Relaxation (RTEST) or Creep (CTEST) test data can be input using these two types. This test data will internally be used to calibrate a Prony series.
    If creep test data are used, then the creep test will be first converted to the relaxation test using the convolution integration,
    ∫ 0 t g ( s ) j ( t − s ) d s = t MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaWaa8qCaeaaca WGNbWaaeWaaeaacaWGZbaacaGLOaGaayzkaaGaamOAamaabmaabaGa amiDaiabgkHiTiaadohaaiaawIcacaGLPaaacaWGKbGaam4CaaWcba GaaGimaaqaaiaadshaa0Gaey4kIipakiabg2da9iaadshaaaa@46C0@
    If the Laplace transform, L MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamitaaaa@36C8@ , is written as:
    f ^ ( s ) = L ( f ( t ) ) = ∫ 0 ∞ f ( t ) e − s t d t MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGabmOzayaaja WaaeWaaeaacaWGZbaacaGLOaGaayzkaaGaeyypa0Jaamitamaabmaa baGaamOzamaabmaabaGaamiDaaGaayjkaiaawMcaaaGaayjkaiaawM caaiabg2da9maapehabaGaamOzamaabmaabaGaamiDaaGaayjkaiaa wMcaaiaadwgadaahaaWcbeqaaiabgkHiTiaadohacaWG0baaaOGaam izaiaadshaaSqaaiaaicdaaeaacqGHEisPa0Gaey4kIipaaaa@4F28@
    The Laplace transforms of the functions g MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamitaaaa@36C8@ and f MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamitaaaa@36C8@ satisfy g ^ ( s ) j ^ ( s ) = 1 s 2 MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGabm4zayaaja WaaeWaaeaacaWGZbaacaGLOaGaayzkaaGabmOAayaajaWaaeWaaeaa caWGZbaacaGLOaGaayzkaaGaeyypa0ZaaSaaaeaacaaIXaaabaGaam 4CamaaCaaaleqabaGaaGOmaaaaaaaaaa@40A6@ , Then the calibration to a Prony series will be carried out based on the relaxation test.
    Normalized modulus
    j MathType@MTEF@5@5@+= feaagKart1ev2aqatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaamitaaaa@36C8@
    Normalized compliance
    You can input shear test data or volumetric test data, respectively, using the continuation lines SHEAR or BULK. The continuation line COMB will allow both shear and volumetric test data together.
  9. For all types, deviatoric component and bulk component specifications cannot be blank at the same time.
  10. Only Direct Frequency Response Analysis is supported.
  11. A nonlinear LGDISP analysis needs to precede the direct frequency response analysis which establishes the base state for the direct frequency analysis. STATSUB(PRELOAD) in the Subcase Information section for the direct frequency analysis needs to point to this nonlinear LGDISP analysis. A dummy nonlinear LGDISP analysis without loadings will mean that the base state is the initial configuration.
  12. The time domain and the frequency domain viscoelastic behavior cannot be specified together. That is, MATVE and MATFVE cannot be used together.
